MID: 30580_N3MEL
Date: 2026/11/05 00:30
Type: Bulletin
To: PKTNET@USA
Subject: For Packet Users Everywhere
Mbo: KD6MTU
Content-Type: text/plain
Content-Transfer-Encoding: 8bit
Body: 4209
R:261105/0030Z 15063@KD6MTU.#NNV.NV.USA.NOAM BPQ6.0.25
R:261105/0017Z 582@K5DAT.#NEWI.WI.USA.NOAM LinBPQ6.0.26
R:261105/0008Z 30580@N3MEL.#EPA.PA.USA.NOAM LinBPQ6.0.25
To make this month's PKTNET more interactive for all packet users—whether on Eastnet, Net105, TPRFN or others—please see the instructions below. The goal is to demonstrate how interconnected and robust these groups and systems are across the US and worldwide.
I have created an interactive check-in process through the Application Services on my node. You can view your check-in in real time on the live webpage here: PKTNET Info - The Packet Radio RF Forwarding Network
Moving forward, the intent is to make select TPRFN forms available directly over the packet network rather than just via the internet. Starting this winter, we plan to roll out the ICS-213, Field Situation, Skywarn, and Packet Bulletin forms. These forms will work the same way your net check-in does now.
I hope this encourages more packet users to participate. This is not a VARA-dependent net; it is for packet enthusiasts everywhere!
The next net is scheduled for Sunday, November 15th, but you are welcome to test this method over the coming weeks.
PLEASE FEEL FREE TO SHARE WITHIN YOUR CLUBS OR GROUPS!
Instructions:
Welcome to the PKTNET Interactive Check-In Port on the Packet Radio RF Forwarding Network.
Follow these steps to connect, complete your check-in, and update your station profile.
Step 1: Connection Options for N3MEL-5 Interactive Port You can access the PKTNET interactive check-in port through any of the following connection methods:
Node Stack Connection: Connect to your node stack (however you access it) to connect directly to N3MEL-5, or alternatively connect to N3MEL-7 and issue the apps command.
HF Radio (VARA & ARDOP): Connect direct via RF to N3MEL-5 on 7.1032 MHz (daytime) or 3.596 MHz (nights).
VHF FM Radio (VARA FM): Connect direct via RF to N3MEL-5 on 145.670 MHz.
VHF Packet (AX.25 1200 baud): Connect direct via RF to N3MEL-5 on 145.050 MHz.
Telnet: Connect via IP at n3mel.ddns.net:8015 select the Terminal Tab then enter (Username: your callsign, Password: n3melnode). In the lower type ahead box enter "apps" <enter>. It will ask for you callsign this is for local logging only, then from the menu selection use #4 <enter> and follow prompts to check-in.
Feel free to check-in via the other modes (but only check-in once per mode)
Step 2: Enter Your Callsign When prompted by the welcome banner:
Enter your amateur radio Callsign (e.g., N3MEL).
Step 3: Review or Update Your Station Profile
Returning Stations: If your callsign is already saved in the station database (pktnet_master.json), the system will display your stored details (Name, Town, State, and 6-character Maidenhead Grid).
You can select fields [1] through [4] to correct any outdated information.
Once verified, select [5] to proceed to operating modes.
New Stations: If this is your first time checking in, the system will prompt you to enter your:
6-character Maidenhead Grid square (e.g., FM29dx)
Operator Name
Town
State
Step 4: Select Your Operating Mode Choose your primary operating mode for the session by entering the corresponding number:
[1] AXIP
[2] AX25 VHF/UHF
[3] AX25 HF
[4] VARA HF
[5] VARA FM
[6] TELNET
Step 5: You have the opportunity to leave a comment.
Step 6: Final Review and Submission Review your check-in summary displayed in the final review box:
Select [1] to Submit Check-In (this logs your check-in and updates your persistent station profile).
Select [2] to Cancel / Return to Menu (aborts the check-in without updating any files).
Once submitted successfully, an ASCII confirmation receipt will appear, and your session will close automatically.
If you can not find either N3MEL-5 or N3MEL-7 in the node stack you are using you may have to select a node or two to find me. If all else fails, you can try RF direct or send a regular SP N3MEL check-in. Please attempt the interactive option first.
Have fun!
Glenn Allison, N3MEL, Downingtown, Pa
(TPRFN) The Packet Radio Forwarding Network
www.tprfn.net
Type: Bulletin
To: PKTNET@USA
Mbo: KD6MTU
Body: 4209
Instructions:
Operator Name
Town
State
[1] AXIP
[2] AX25 VHF/UHF
[3] AX25 HF
[4] VARA HF
[5] VARA FM
[6] TELNET
Have fun!
www.tprfn.net
